cruzenmike
- Feb 10, 2017
- 59
- 858
Good evening all. So here is the story; I will keep it short:
I have a Cub Cadet LTX1050. I purchased it used and have put a significant amount of money into it since I got it (governor, regulator, carb rebuild, pulleys, belts, pto, etc.). After about 20 hours of doing all this work, it is starting to act up again. I was just handed down an eXmark which I will use to cut the grass, so the Cub Cadet has been re-purposed as a utility machine. I have a roller, aerator, wagon and snow blade. Now that I am starting to have issues with the rider again, I am thinking of just buying something new to have a dependable backup mower to the eXmark and to take over the heavy duty tasks that I am currently using the Cub Cadet for. Here are my only two options:
Cub Cadet GT50 for $2699
25HP Kohler
50" Stamped Deck
K58 Hydrostatic
Pros: Works with existing snow blade, has great steering (light), powerful engine, great styling
Cons: Transmission, although better than a K46 is still a limited slip (not as good for snow or pulling attachments), complaints of finicky safety switches
Husqvarna GT48DXLS for $2699
24HP Kawasaki
48" Fabricated Deck
K66 Hydrostatic
Pros: Arguably better engine, lifetime warranty on deck, more robust transmission with locking diff.
Cons: Stiff steering with wider radius, limited to 3.5" cut height, requires buying a new snow blade
From the specs alone, the Husqvarna is the clear choice, especially being discounted $300 to match the price of the Cub Cadet, but that cost is quickly consumed by the new blade I have to purchase. Am I crazy for still considering getting an XT1 because of the cheaper price in the end and the easier steering, or will I regret not having the rear locker when pulling a 920lb roller or pushing snow? Please share your thoughts and experiences. Thank you.
Mike
25HP Kohler
50" Stamped Deck
K58 Hydrostatic
24HP Kawasaki
48" Fabricated Deck
K66 Hydrostatic
Mike
