Over choked???
If you look at your spark plugs, they're probably black.
It wouldn't hurt to change the oil, too.
Need the model number should be on the valve cover or the engine shroud. Example 402777-0123-e1. Should look like that. Find those numbers
The only model number was in a previous post that was the only model can find. Changed oil yesterday.
