I was looking at blades for my mower and recognised the 'Gator' blade. It is advertised as a 3-n-1 blade. I looked at the Arnold brand Extreme blade and it looked similar to the Oregon Gator blade. The biggest difference was the angle of the twists on the back side of the blade.....they are in opposite directions. If you imagine the twist as an airfoil, one would direct air to the center and the other to the outside.
Any thoughts on which would be a better all-around blade? I use the bagger most of the summer and then will use it this fall for leaves.
Toro LX425 42"
