Once hot...no start
ocb
Gotta Troy Built rider with a Kholer Commander14 engine. Runs well and mows well untill its hot. After its hot and I disengage the deck it stalls out and cranks but won't restart. Any help and info would be greatly appreciated!
:welcome:
It could be a carburetor issue causing it to run too rich, which would make it stall and then not start again due to a flooded combustion chamber.
Try cleaning out your carburetor and see if that helps. :thumbsup:
When it does that again, check for spark. My pusher would do that. What happened is the heat causes the coil to expand, breaking contact.
