Hi, I recently got this old Toro from my late grandfather. I'm not sure the model or serial number because all the tags are gone. I have removed the engine from the deck and found a engine number on the cover 47PD3-213707 which I understand is the two stroke Suzuki GTS 121 cc. I'm looking for some were to get parts, but no luck. Could anyone help me Identify the model and were to get parts, looking for Mikuni carb gaskets, exhaust gasket, and air filter? Any help would be greatly appreciated. Pics attached.
cpurvis
It's been a couple years since I had to work on the carb of my Toro/Suzuki.
I had no luck at Toro dealers. Both told me parts were no longer available.
I think that's a lazy parts man's way of saying, "Go away, I don't want to look for anything."
I got my carb parts from a dealership that doesn't even sell Toro mowers.
The mower model plates on the two Toro mowers that I have are located on the mower deck between the rear wheels and on the underside of the cross piece that holds the throttle cable and dead man bar.
You should be able to get what you need from the engine model without the mower model.
