Old to new and questions
JAW91
Ok, so my old mower (Snapper SR1028 series) stopped working last Sunday (I think the motor locked up). This past Tuesday I bought another snapper, this ones has a 33” cutting blade and my questions are #1. What goes in the chain drive next to the right rear wheel as far as lubricant. #2. I was cutting the lawn earlier and the mower just refused to go into gear. I think this is my fault because I was trying to go in reverse and forgot this mower is not a shift on the go model like my old one was so I kind of jammed it into gear. Now the mower will not go in any gear. I replaced the drive disk and this did not resolve the issue. The reason I thought this was the issue is because when I would put it in gear I could still spin the drive disk fairly freely while it was in gear, so I figured it was worn to the point where it wouldn’t make contact anymore. What else could cause this? The reason I took the side cover off near the right rear wheel is because I thought maybe the chain broke, but the chain is intact and looks fine.
I attached the pictures of my new one next to my old one. The one on the right is my old one. One on the left is my new one.
The new mower.. the one with the issues going into gear is the one with this serial pictured..
