Have one of the old snapper push self propelled with the speed control lever down by the left rear tire. Trying ot find a picture to see how that control lever, spring, bracket all fit together.
thanks in advance
#2
wingless
Welcome to the forum.
The lever is easy to install.
Angle lever perpendicular to handle, then rotate to engage lower U bracket.
Push spring and washer away from handle bend, towards tang stop
Put handle into U opening on speed plate
Attach small arm to driven disc mechanism by rotating
Put clip onto shift arm opening then poke small arm through holes
