My mom's Toro Recycler 22" self propelled walk behind mower is leaking oil. I believe this is a Tecumseh 6.5hp, but I am not 100 % sure. Initially I was having some trouble with the starter as posted here:
Bad Battery ? Thread
Anyway, here's a pic from where I think the leak is from:
I found an old (~40 years!) service manual in my mother's basement. I think this is the breather? Just not sure what to do next.
Before she used it the 1st time I changed the spark plug, oil, air filter and put on new blades. I did drain the oil from the plug under the deck instead of tipping it over sideways and draining it from the fill tube like the owner's manual said, but I can't imagine that causing any problems... Anyway, the last time she used it she said it is using a ton of oil and there was oil all over the deck. Keep in mind that I sprayed the entire engine with degreaser and hosed it off prior to her using it the 1st time, so it was clean. Here's what it looked like after she last used it (before I degreased and hosed it off again trying to find the leak in the picture above).
What do you guys think?
