poohbutt40
- Sep 17, 2016
- 1
- 3
Anyone know what size fitting to use for an 24HP Briggs.I want to purchase a Drainz it hose for oil changes
I do not know the size, but Briggs makes two of their own drains. One is the plastic quick drain with the replaceable hose. The other is a permanent option which I had used on my 18hp Briggs. I have included a link to that hose. You can ask Briggs directly and they can tell you if it will fit up.Anyone know what size fitting to use for an 24HP Briggs.I want to purchase a Drainz it hose for oil changes
Thank youDrainz-it STAN1438
14" length Standard 3/8 NPT fitting
Thank youI do not know the size, but Briggs makes two of their own drains. One is the plastic quick drain with the replaceable hose. The other is a permanent option which I had used on my 18hp Briggs. I have included a link to that hose. You can ask Briggs directly and they can tell you if it will fit up.
1723165SM Briggs and Stratton Hose-Oil Drain OEM
The best-value buy; Briggs and Stratton 1723165SM Hose-Oil Drain – Replace cracked drain hoses easily. Flexible yet durable construction. Shop now!www.briggsstrattonstore.com
