SeniorCitizen
- Aug 28, 2010
- 141
- 2,288
I saw a fellow changing oil at an auto service center and was using a neat tool that prevents hot oil reaching the hand and also prevents the drain plug from falling into the container. It looked similar to a 6 point socket with the side cut out and was magnetic. It was arranged on a cable 6 or 8 inches long with a handle attached. After the drain plug was loose this tool was placed on the drain plug for final removal having the plug retained via the magnet.
Ever see one and where do I buy one or 2? I've searched the web. Hopefully you can search better than I can.
