Mike196767
- Jun 22, 2019
- 1
- 1
I recently replaced rods and adjusted valves and mower would run normal for few minutes and then will lose power and start smoking. Not sure what causes that? Any help would be greatly appreciated! Prior to adjusting valves carb was also taken apart and cleaned so not sure if that's the problem ??
