Np power on a Husqvana YTA22V46
Roger G C
The engine runs fine put there is no power to move mower. At first had problems with reverse, but now forward is also an issue. Any incline is a problem. what can be the problem, have others had the same experience?
Your drive belts are slipping. Possible causes, bad belts, tensioner not working properly, variable speed pulley sticking, bad idler pulleys. You’re going to have to do some inspection work, as it could also be a combination of causes.
