Hi Everyone,
I have a Husky 18 ton log splitter that has a Briggs 110412-0158-E1 engine on it. It may not be the original engine because it has a Yard Machine label on the rewind pull starter. I bought it used a few years ago and it has never run great but it does start every time and it runs well enough to split wood. The main issue is that it surges very dramatically. I decided to really look at it today. I checked the valve lash and it was close but I did adjust it with no change to the performance. I then took the air cleaner/housing off and ran it with a wide open carb. It ran great!!! Ok, so why? I started with installing the filter housing (no filter) and it did not run as well. Not awful but there was a difference. Now, what am I missing? I noticed that on the face of the carb there are 2 bolt holes for mounting the filter housing to the face (with a gasket) and 1 “passage” hole into the guts of the carb. With the housing installed it blocks that hole about ½ way. There is no passage into the housing. This hole is unfiltered to the atmosphere. Does that make sense? Is it possible that this setup is incorrect? Did the previous owner combine parts and he created this issue? Are there other reasons that the engine would run so great with no filter/housing but not so great when installed? The filter housing type and carb face example are shown below.
