No power, running rough
acudanut
Briggs & stratton intek22 hp twin V. Was running fine but not charging, replaced the alternator and regulator, put back together, ran fine and mowed for couple of hours. Next day went to mow and was running rough and had no power. Thought it might be bad coil but both plugs have spark. Any ideas before I take it to a shop?
mechanic mark
Check air & fuel filters for replacement.
shiftsuper175607
Do you think it is running on only one cylinder?
Possibly a valve problem if so.
acudanut
Has new air and fuel filters this spring. Was hoping it was not a valve problem
