As the title says, I have NO power to the console. Wont start and no lights or indicators on console. Brand new battery. The deck actuator works fine, indicating good charge on new battery. A couple of weeks ago, when I tried to start it, I got weak lights on the ignition when attempting to start and a sort of buzzing from the engine area. This made me think the battery was at fault, so I installed a new battery. Any idea where to start with troubleshooting?
I always have a spare on hand. So I popped out the old one, tried the new one & everything worked. It had some corrosion on it, which lead me to believe it might be bad.
#6
MBDiagMan
Look through the threads. There is one named something like Grasshopper owners read this. There is a link there to "The Mower Shop." In there you can find a wiring diagram for your mower.
