New Snapper 6.75 blows oil
BlueStarDaddy
1 year old snapper self proppelled 6.7 engine...starts right up and runs!
Im getting significant oil splatter on the deck looks like from exhaust muffler, plus some occasional blue gray smoke
SOOOO... I gotta blown head gasket in there? Never heard of a piston going in one of tese mowers
Frank in Texas
mechanic mark
May be under warranty, check paper work & return mower for repair or replacement.
BlueStarDaddy
Thanks for reply but I'm not original owner i buy and sell lot of stuff .
I get a lot of mowers
Got this in a recent lot looks showroom new but has obvious problem
Check the oil level. If it is overfilled I'm guessing you have gas in the oil which is causing your problem. Dump the oil, rebuild the carb with a new float needle and seat and you should be good to go.
