peteclark3
- Jan 1, 2012
- 15
- 47
Hey folks!
My son and I recently purchased a new-in-box Coleman Powermate 6250 generator. We were looking for a good, reliable generator for which we could actually find parts... this one being new in the box, garage kept for its 12+ years seemed like a good bet. Pics attached.
Upon trying to run the generator for the first time, it seems that unfortunately the years of being in the box weren't very kind to the carb. Gas immediately leaked right out of the air cleaner due to a stuck float. We unenthusiastically took the carb apart to free the float, only to see some rust / etc gathered at the bottom of the bowl; I assume due to condensation due to temperature change over the years. We did a quick clean of the carb, started it up, and it ran, but sputtered a bit, when not under load. Under load it ran a bit better, but there was still a bit of a sputter.
Soooooo... we ordered an aftermarket carb to replace it entirely, to eliminate that entirely (since every search on the topic said "carb issues")... installed the new carb, fired it up, and... the sputtering still happened. (Note, this is with a brand new spark plug too - not the one that came with it... the engine sounds the same with both, but we kept the new one in anyway).
Back to the old carb, I chem dipped it over night (removing gaskets/nonmetal items of course) and sprayed it super crystal clean this morning with carb cleaner.. the complex gasket in there still looked good and flexible. Put the carb back on, fired it up, and it still sputters... the video below is the sound it makes as of right now (taken just 10 minutes ago). Still, under load it runs a bit better, but still sputters occasionally..
It's not "intolerable" but we really would like it to run evenly when not under load, because it does exhibit similar symptoms when under load, occasionally.
At this point I'd take it somewhere, but wanted to check here first, because I tend to think they will just tell me "that's how it sounds when not under load" but I've seen YouTube videos of this very generator running when not under load, and it doesn't sputter.
Note that we of course run it with non-ethanol gas, and it truly had never been run before, the tape was original on the box, no tears, not re-taped, had no oil in it, etc.
At this point I wonder if it is something electrical... faulty low oil sensor? Needs a new magneto (I know this is rare)... ? I'm sort of getting into uncharted territory for myself here.
Thank you for any help you can provide, and if more information is needed, please let me know!
Pete
Video of the sputter: https://www.youtube.com/watch?v=7-ZAmRfCGsE
Photos with engine model numbers and such:
Pete
