Repairs New Member Question
3Tractors
Hello All. I have a 2002 Yard Machine 16.5 LT (purchased new). The tractor is leaning to the left (not the deck). I have raised it up on jack stands and looked for the culprit but I do not see any breaks or cracks that would cause this. It is still in the air as I am refurbishing the deck. I'm hoping someone can chime in to give me a hint about what to look for. Thank You in advance......3T
deck~dragger
Welcome 3Tractors. I am sure you have checked for equal tire pressures.
Check the front wheel spindle on the leaning side, possibly bent.
Also, I have seen the same tire size by a different manufacturer actually be shorter or taller than the original when placed side by side, if you happened to have replaced a tire recently.
