New member, Ontario
Breezy
Just received my new Canadian-spec Craftsman T3200 944.604311. As far as I can tell, this is basically a black 917.20390 with an electric PTO and the K46 transmission.
I did a lot of research including here and it's been very helpful. Thank you.
This replaces a 1993 AYP Yard Pro 12hp 38". The Yard Pro is still going, but I decided it was time for an upgrade.
Welcome to LawnWorld, familiarize yourself with tractor by reading operators & engine manuals thoroughly, also make sure tractor was greased from factory & see if they greased steering sector & pinion gears, if not grease them you'll be glad you did.
Hi and welcome to the forum. Congrats on the new Craftsman! :thumbsup:
Thanks for the heads up - turns out they weren't greased. Seems they missed that item on the "Lubrication Chart" at the factory.
