Need tires for my Toro reel mower.
Smokee
I had to put this away more than ten years ago, when the tires fell apart. I just pulled it out of storage, and if I can't find new tires for it, sadly it will get junked.
I really like the way it mowers, but without tires it is useless.
The tires are hard rubber, and airless.
Can anyone help?
Please post the model numbers for your unit.
Smokee
Thanks for your quick reply.
There is a badly worn decal next to these stamped numbers.
Model 61102 0133 01 6802073
If the last seven numbers are the serial number, would the first two 68XXXXX, be the year?
if I can get tires, I'll also look for decals, and do a re-finish with paint and decals.
I love the way this mower works.
Smokee
Rivets,
It looks like I gave you the info off the B&S engine.
I found the chassis tag, I can make out: 10013 805971
I hope this helps.
Yes, your mower was built in 1968. Go to this website, which will give you a lot of info on parts. Most of the major parts are no longer available through Toro, but once you have the part number, you can surf the web as there is always someone who has them in their storage building.
Toro |
winesellar
I have the same mower with an extra set of tires. I will sell you the tires because Im actually going to sell the mower because I dont use it. You can reach me at redwinedaily@hotmail.com
winesellar
My Toro is a 1964 and the extra tires are in good condition.
