Need Tecumseh carb 632755
Terry Rader
Do you have a replacement carb for a Snapper Model # 21405-2? The part number on the carb is 632755.
Romore
That is a casting number, we need the engine model and spec numbers to help you.
Sorry Romore, that is a carb part number. The reason the OP is posting is that the carb is no longer available. I would suggest the the OP get a rebuild kit, have the carb ultrasonicly cleaned and then rebuild.
