need help
kody
lawn mower cut off,with air cleaner off i can put a little gas in carb it starts and runs a for about two seconds,it is getting to carb,it is a kohler engine,does anyone know how to test the carb solenoild,i am getting fire to solenoild with test light.thanks.
The easiest way to check the solenoid is, Does it click when you turn on the key. If yes than it is working, if no then check to make sure you have power, as well as a good ground. If that is true then replace solenoid.
