Hello,
I am looking for some assistance with determining whether the ignition switch on a Murray Lawn tractor (model # 40508x92G) is good or bad.
What I need to know specifically is what positions should give continuity and which ones shouldn't.
I have included the factory electrical diagram for my mower, and AFAIK ( I won't assume anything) it is correct for my mower. I double checked the wire colors on the harness and they do match what is shown on the attached diagram 100%
If someone sees that a simple continuity check for this particular switch/circuit would be inconclusive in knowing 100% whether the switch is ok or not, please point that out to me.
In case anyone is wondering, what happens is turning the key to start does absolutely nothing, just a small click - no engine turn over, nothing. Fuse is GOOD, The battery tests strong (12.75V), and, I think I have ruled out the solenoid. There is full voltage coming into the solenoid (RED lead), but I get no voltage on the ORG lead (when disconnected and measured as I turn key to START). Maybe the PTO safety switch but I want to rule out the ignition switch first.
Thanks,
Alan
Thanks,
Alan
