Export thread
Need Help Trouble Shooting MS280 Chainsaw
#1
C
chooch
My Ms280 wouldn't start, found the issue was no spark with new spark plug. I replaced the ignition coil and gapped it. saw started right up and ran well for about 10 minutes. the it would run but not idle. I restarted it a couple of time but it would stop when I tried to idle it. then it stopped and now will not start. also now it has a significant amount of resistance when I try to pull the starter cord. Has new fuel and plenty of bar oil. Thanks for any help!
#2
D
deminin
You might want to recheck the coil gap again. Perhaps you didn't get it tightened enough, and it has shifted back onto the flywheel, and is dragging.
