I recently bought a 99 Troy built 54inch cut and 25hp briggs and stratton engine. I love the mower and it runs great but it does have an oil leak. It is a slow leak so im assuming its a seal or a gasket. It leaks pretty much dead center under the engine on the ground. I see most of the sludge from leaking on the left/drivers side of the engine. I don't know much about these engines so I am wondering what are the possibilities. It does not appear to be the valve cover so anyone have any ideas what it could be? Thanks
