Need help finding a carb
PTmowerMech
Pretty please.
Briggs 4hp
110702 3110-01
Code 8803020
Part number for the carb looks to be 492545
Can you use the LMS10 replacement? If so pn 491330 has been superseded to 492496. The 492545 (LMS11) is NLA so you might be able a NOS one out there.
PTmowerMech
English please...LMS10? NOS, NLA?
I didn't check this out before I gave the woman an estimate. FIgured they were a dime a dozen. The one I seen this morning was like $50.
Στην πραγματικότητα είναι τα αγγλικά.
LMS-10 \u003d αριθμός μοντέλου καρμπυρατέρ καρμπυρατέρ Walbro - πρέπει να είναι σφραγίδα στο καρμπυρατέρ. Απλά ότι το LMS-11 ήταν το τελευταίο μοντέλο που χρησιμοποιήθηκε.
NOS \u003d Νέο παλαιό απόθεμα
NLA \u003d Δεν διατίθεται πλέον
Τώρα τα πράγματα ξεκαθαρίζονται;
Actually was English but the above is the Greek translation of the following.
LMS-10 = Walbro carburetor carburetor model number - should be stamp on the carburetor. It just that the LMS-11 was the last model used.
NOS = New Old Stock
NLA = No Longer Available
Now does clear things up?
PTmowerMech
Not to change the subject, But I have this one soaking in CLR, and by golly, I think it's working.
This is why I didn't want to try and rebuild it.
UPDATE: I think I found one on Ebay.
PTmowerMech
NOS = New Old Stock
Crystal clear. HA HA HA HA HA HA
Just pulling your leg. I figure you were thinking I was typing Greek so I did. Yes some the abbreviations use to get me too and I still ask to have local slang words explain from country to country. They even the same part by different names too.
And I had a few like like that but I have use white vinegar to clean them.
tom3
Might need to swap jets from the OE to the new one if a Chinese replacement.
PTmowerMech
The one I found says OEM. But won't know for sure til it comes in.
tom3
最好的方法
Zuì hǎo de fāngfǎ
