Hello Friends!
I don't know is this a good place to post my question.
I am just going to buy my new home. I am wondering that is buying better or building? Any advice?
look into when and how your house is built. if its built in the 70's they normally used this metal bridging in between the floor joists. not solid blocking. the metal bridging isnt good because when weight is put on the floor it pulls on the nails and creates a squeak in your floor. they are also not code in houses built now. it now most commonly solid blocking. but if i were to build a house i would use the wood cross bridging. it is more work but it pays off. also, i wouldnt get a house with alot of pine trees around it. they like to snap.
Hello Friends!
