Hi folks,
I'm new to this forum so excuse me if I've posted this question in the wrong hole.
I own an old Victa Utility lawn mower with the original Victa AE 054 AA90 Powertorque engine. The mower has been well maintained over the years and runs perfectly since it was built over 40 years ago. Lately though, the mower has developed the strange habit of blowing the foam filter out of the decompression valve. I have replaced it with a brand new decompression valve and it suffered the same fate and was destroyed. The foam rubber is blown out in several pieces through the four holes in the back of the decompression valve cover. The engine still runs fine by replacing the valve with an old spark plug to block the threaded hole, but I am wondering what might be the cause of the strange problem? It seems like it might be an engine timing issue but as the timing can't be adjusted on powertorque engines I am mystified as to the cause of the problem, and how to resolve it. Below is an image of my brand new decompression valve which, as you can see, has been rendered totally unusable. The engine compression destroyed completely the plastic vacuum hose fitting, and even tried to blow the diaphragm out the side of the valve!
I would be very grateful for any help the forum could give me to fix this problem.
Thankyou.
Thankyou..
Thankyou.
Thankyou..
