My 23HP Kohler engine is beyond repair. It has a cv23s spec 75562. It appears that they no longer make a direct replacement engine. Does anyone have any suggestions for an engine that may work?
The connecting rod came loose from the crank. The crank is damaged along with the governor, and of course the rod. While the rod did not go through the block it did put a crack in it.
