my mower
JBIGUNK
my murray push mower shakes and has black smoke coming out of exhaust pipe
KennyV
WELCOME to LMF...
The black smoke indicates it is getting too much fuel... That will cause ut to run very rough & shake...
First things to check....
Is the choke full open? Is the air filter plugged? (you can remove it , and then start the engine, if it runs a lot better... get a new air filter).
Post back if it is neither of these two... :smile:KennyV
