Not much to go on. What do you have for a engine? 2cycle or 4 cycle? Gas and oil mix? Make and model ? You need fuel, spark, compression, and timing and it will run. If fuel is running out of the engine when you try to start it you may have dirt in the needle valve inside the carburetor or clogged air filter.
