My first question here. Putting the mower deck back on a 98-99 model
rick-barber
  • / My first question here. Putting the mower deck back on a 98-99 model
This lawn tractor / mower is a model number 660-669.
I got this lawn tractor from my son who purchased it used. So it has been around a while. I put a seat support on it last year. The issue the mower had was it had a very loose steering setup. I had to turn it between 10 and 2 to try to keep it going straight. That issue has been corrected.
I also wanted to make sure the blades were sharp so before I fixed the steering, I removed the deck. I did so with out any manuals. I pretymuch removed all the pins and washers I could see and due to old age did not pay attention to where everything was attached.
Today I started putting the deck back on and after attaching it once, then removing it and putting it back on again. I got down to re attach the mower belt and discovered that the stabilizer plate was not fully attached. I am out of cotter pins and have no idea where this stabilizer is supposed to attach.
If this forum is like most others I have visited over the years, I expect some one here will be able to tell me exactly what I did wrong in the assembly process. I Sure do hope so. I can provide pictures if necessary but I do not have any at this point.
rick-barber
IO figured it out. The stabilizer plate needs to be flipped over toward the back of the mower and have the stabilizer rod that runs toward the rear where to spring attaches run through it. DUH
