Have an old Murray. See parts (p124) here: http://d3cmirsdb60x3h.cloudfront.net/schematics/murray/85-36511x18.big.pdf
The problem is now when I go to put the wheel back on the hub seems to wide to fit so as to have access to the cotter pin hole, not to mention the washer that goes against wheel hub and cotter pin. Any ideas? The other front tire has sufficient room for both, Thanks so much.
