Hi there ,new to the forum. Hope someone can help me out.
Im just about finished putting my tractor back together after letting it sit for to long. I had to order a few springs for the drive system. But now i have one problem. number 26 the spring and number 32 thats the assembly that rotates around to put tension on the pulley assembly. I just can seem to locate the correct placement for that spring. I believe it hooked behind #44 but i cant get the setup to work.
