I have 3 Murray mowers ( had 3 front engine riders) as Bert said the BRAKE safety, is under the RIGHT foot floorboard, the PTO ( blade engage switch) is inside the dash console ( hard to see without a light ) attached to the lever mechanism, the neutral switch is located UNDER the BATTERY BOX, ( must be removed to see it well, or remove LEFT rear wheel, it's located on shift lever bracket, the seat switch is under the lift-up seat, but has nothing to do with the starting circuit operater MUST be in seat... Blade engage lever in blades off pos., and clutch pedal pressed down, trans should be in NEUTRAL also, ..IF all switches are wired in the system.....
