Mulch Kit Worth It...
YardMonkey
Is it worth the $150 to purchase a mulch kit for a Toro 42" TimeCuttrer ZTR?
Use it only to cut my yard...wondering if it would mulch up the leaves and pine needles.
A
AmericanTurf
Guest
I think you will be fine mulching. Mulching is a good thing as long as you dont let the grass get to long. The pine needles may require a lawn dethatching the following spring...depending how many needles you have. But yes the mulching will mulch your leaves and pine needles.
