I have a Yard Machine with a 12.5 Briggs and it only fires once. Could this be a ignition problem?
yo Boo
you jolly on the spot today must be doing good
Don't understand what you mean by " only fires once " explain further ..
in the meantime you may want to go over this ...
View attachment 32528...View attachment 32529
click on items , click again to enlarge or use your puter zoom feature ...
When I turn the key the engine fires once and continues cranking. it does this every time I try to start the engine
