MTD Yard Machine Model and Year Info
cgaphiker
Hey all. I hope y'all can help me figure out what year an MTD garden tractor was built. I have the model number, but when I plug it in to MTD's site, it gives me a choice of years of manufacture. I have no idea other than it was built after 1998. I have used part numbers from 2000 and they fit with no problem, but I would like to narrow it down to the actual year that it was made. I do have the serial number too. Any help would be appreciated.
gfp55
Maybe you could post the model# & serial# and somebody may be able to help you.
cgaphiker
That probably would be helpful wouldn't it. :)
Model # 14AS825H000. Serial # 1A060B10119
gfp55
I don't know if this is what you are looking for, but if you go to partstree.com, click on mtd, put in your model # it says your tractor is 1997-2001. If you take the time to look at all pictures on the list you may be able to get an idea about what year your tractor is. I hope that will help you. Good Luck
Fish
Post all of your engine"s model numbers.
Date of Manufacture from the serial number is January 6, 2000 which makes it a 2000 model.
