MTD Yard Machine model 13A6672G129 and no manual. MTD says no serial #, no manual. Please help
jdavis493
Greetings everyone. My neighboor recently gave me this and it's mowing again after some work. I tried locating the MTD sticker under the seat. but only found a "place tag here" message. Is there another place the serial may be located? I was able to get the model # from a prior post on here telling how to get from the engine tag. Can anyone share their manual DL with me or even their serial # please? I'm desperately wanting/needing a manual so I can keep this baby mowing. Thanks!
If you are trying to use the MTD website to look up the owners manual then you can put the model number in the proper field, and then put eight zeroes in the serial field.
Thank you Ilengine! You're post from 2017 is where I found my model number, my mower had the exact same engine codes as the other gentleman. You've saved me twice in one day!
