MTD 672 clutch safety
WLP
WLP here,
Where is the clutch safety switch on a MTD riding mower MODEL 13am672go88 ? ( 672 )
I know it is under the mower and above the deck. Now tell me exactly where it is.
Follow the wire will not work for me. Have used, buymtdonline.com, and received a wireing diagram.
Has anyone replaced this switch? HELP HELP
WLP here.
The breakdown manual was good in that the safety switch appears to be very close to the rear axle/transmission. Exact location will be discovered when I remove the
deck. Deck belt will have to be replaced. Has some chunks out of it. Wish I had
a table/rack to put it on. Something like a motorcycle shop has. Old and don't like getting on the ground. Thank you for the help. Will post when I find the switch.
