Ms230 starting issues after use
canadanorth3030
Starts fine, works fine until I stops the saw. Then no start, its like it gets hot. Let it cool down for awhile and starts perfect most times. I can used it for it til it runs out if gas but If I stop in between... No Start!I changed carb, coil, gooseneck. But this issue was there from new. Far from dealer ti service do I never bothered years ago now lol.
Remove the kill wire from the coil.
This means that you will have to choke then open the throttle to stop it so it is only a diagnostic proceedure .
Problem goes away = wires shorting out when hot .
Problem remains = carb not adjusted properly, most likely too rich on the Low jet .
Fish
When you try to restart it hot, Hold the trigger all of the way down, and use absolutely no choke, and try to start it. See what happens.
