mower_blades stop working ater 10 - 15 minutes
jgriffi5
mower blades stop working after about 10 to 15 minutes. let it cool down and try again it works. then in about 10 minutes blades stop. pouland pro ex700 mower. with a brigs & Stratton 23 hp motor.
Check the battery voltage.
If the alternator is not working then the voltage will drop when you engage the PTO and eventually the PTO will cut out.
Clean out the clutch with compressed air as accumulated dust will enhance overheating problems.
Check out the resistance between the two wires.
Post your results
