Mower won't turn over
ncpete
Exciting rainy day here in the Carolina's, where I had hoped to get to work on a very overgrown yard, but there was no real let up. So, instead, I have spent time troubleshooting a Sabre (by John Deere) mower that refuses to turn over. Not getting a decent read on my multi-meter, I think I need to buck up and get a decent battery for the poor old machine. Then, knowing what I have for charge, I can actually really begin to trouble shoot any electrical issues I may have.
I don't really expect any, but I parked the machine about 3-4 years ago when I had two things go wrong at the same time, both of them really quite simple> rear tire needs replacing, and fuel lines gave up the ghost. They conspired against me with the 90 hour work weeks I was putting in, to let other issues come up during the mowers extended retirement. Not working now, really don't want to push mow my 1/2 acre yard, considering I will also be responsible for our rental property's yard on a regular basis, soon.
I have in the past been responsible for first line service of mowers and such when I was renting out products like this, so I am familiar with what steps I need to take, but in spite of the fact that I have owned this mower for almost 7 years (second hand) I know nothing about the most common failure points to look for. Any thoughts?
Try this troubleshooting guide.
Electrical* problems can be very easy or very difficult, depending on four things.
1. * How well you understand basic electricity.
2. *What tools you have and know how to use.
3. *How well you follow directions.
4. *You don't overlook or assume anything and verify everything.
Remember we cannot see what you are doing. *You are our eyes, ears and fingers in solving this problem. *You must be as accurate as you can when you report back. *The two basic tools we will ask you to use are a test light and a multi-meter. *If you have an assistant when going through these tests it would be very helpful. *These steps work the best when done in order, so please don't jump around. *Now let's solve this problem.
First, check the fuse(s), check battery connections for corrosion (clean if necessary) and *voltage - above 12.5 volts should be good.*
Second, check for power from the battery to one of the large terminals on the solenoid. *One of the wires is connected directly to the battery and has power all the time so one of the large terminals should light a test light or show 12 volts on a meter at all times.*
Third, *check for power at the small terminal of the solenoid while depressing the clutch/brake pedal and holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). If your solenoid is a four wire solenoid, check both small wire terminals as one is ground and the other is power from the ignition switch. *If your solenoid is a three wire solenoid, make sure the solenoid body is not corroded where it bolts to the chassis of the mower as this is your ground path back to the battery. *If in doubt, remove the solenoid and clean the mounting area down to bare metal. *If there is no power to the small terminal then your problem is most likely a safety switch, ignition switch or in the wiring.*
Fourth, check for power on the other large terminal of the solenoid while holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). *If you have power what is the voltage?
Fifth, check for power at the starter while holding the key in the start position (assistant again). *If you have power what is the voltage?
Sixth, check your ground circuit back to the battery.
After you have gone through each of the above steps, let us know what happened when you did each step. *At that point we will have great info to tell you how to proceed. *Remember you are our eyes, ears, and fingers, so please be as accurate as possible.
Be as specific as possible with voltage readings as this will help diagnose your problem quicker. *If you do not know how to perform the above checks, just ask and I will try to guide you through it. *Youtube also has some videos and as you know a picture is worth a thousand words.
ncpete
That is a great trouble shooting guide. Thanks!
Fuses - good (only could find one?)
connections at battery, clean
battery ground - good
tomorrow I will recruit my son to be my assistant so I can check voltages at the various solenoid locations.
voltage at the battery bouncing all over. Think I will be picking one up, if the charger doesn't make a difference tonight. Definitely did not get 12v when the meter settled down.
