lakeviewpe
Was there any reason in particular you were changing the blade? or was it just dull? Check your air filter, See if it is full of oil. If so buy a new air filter, check the oil, make sure there is no gas in the oil. If so, change the oil.
Yes the needle goes up into the hole as connected to the float.
You don't need to trash the mower yet, even if it turns out to be a repair you can do, it might cost you about $80 at a shop to have done, which is still better than the $200 for a new one.
