Well Smash, it appears the carb. is a bit ill, best solution is to remove and thoroughly clean the fuel tank, replace the fuel-lines, filter, and shut-off valve is so equipped, THEN, a super cleaning of your carburetor, that's the best way to insure you have no problems with the fuel system. Always drain the tank, and run the engine out of fuel, before storing for long periods.
