Mower stalls when engine is parallel to ground; runs fine on incline
I know times are tough & things are tight but you don't get charged for using the internet by the word.
So because none of us are physic no one will have the foggiest idea what the hell you are talking about.
The computing worls has a saying "Garbage in = garbage out "
when it comes to forums Nothing in means nothing out.
What Bert is saying is, our Psychic and ESP powers are not working and we have not idea of what you are talking about. Maybe if you bothered to post the name and model, plus serial numbers of both the unit and engine, we might be able to provide you with some help. We could give you a bunch f smart +&(786 replies, but that would take time away from those who understand how to post problems and give us a good picture of what is happening.
The only thing I can picture, is the difference in float level, from flat ground to an incline.... :confused2:
Is there a chance you have water in your fuel tank or in your carb float bowl that moves and and unblocks the jet on an incline.
