Mower for PA slope? Zero turn? Self propelled push mower?
nanobooboo
  • / Mower for PA slope? Zero turn? Self propelled push mower?
Hi, I'm from SC so never mowed anything that wasn't flat. Have a good sized yard around the house that sits on a hill. Guessing around half an acre or so. What's the consensus? I have a zero turn SCAG that has the perpetually leaking B&S 25hp commercial; great mower otherwise. Suggestion box is open!
Tiger Small Engine
A half acre is not a big yard. Zero turn mowers work great on hills and slopes. A self-propelled mower would be fine too for a half acre.
MParr
Try the leaking Scag out. If it handles the terrain, think about repairing or replacing the engine on it.
TonyPrin
Generally, I would suggest a self-propelled mower for 1/2 acre. But you already have a zero turn that should easily handle your need I suggest you stick with that. You should consider a self-propelled push mower for areas the zero turn can't handle well.
