Mower dies when i sit down in the seat
dermderm
I'm having an issue with my Husqvarna zero turn. The mower will not start while sitting in the seat. When I'm out of the seat the mower will start and run but as soon as I sit down it dies. I've changed out the seat sensor with no luck. Could it be a bad smart switch? Any help is appreciated. thanks
sgkent
sounds like the wrong kind of switch. Some switches are normally open, and some are normally closed. When the user sits down they do the opposite. Make sure you got the correct part for your model and serial number. Without those, by the way, no one here can look up anything to assist you, nor can they see it over the Internet.
