Mower Bogging Down
sounds like throttle needs adjusting? or lost compression. maybe new coil?
Following the advice of the last poster, I did some research on symptoms of a bad ignition coil. They sounded very much like the problems that I was having, so I went ahead and replaced it. Tonight I was able to mow the lawn without any problems, so we'll see if that is the fix I was looking for.
