The easiest possible way to replace fuel lines in tank! Got to get the hose through two holes and the 2nd you can't see!! Bout ready to rip my hair out! Any easy tips tricks let me know please. Lol. Pain in the a**
Had to do my McCulloch 3200, awhile back,the trick to installing fuel lines is to buy way more than what you THINK you NEED ! The reason being , that when working with fuel lines on a saw that the lines entering the tank through a hole are a tad bit larger than the hole (or should be) to prevent leakage. to get these lines through the holes is more
than frustrating, and challenging, I find the easiest way is to use a RAZOR-Blade (knife) to slit the fuel line at a VERY LONG angle ( about 2 to 3 or more inches ( practically cutting it into 2 halves) (reason for extra line) then cut off one of the 2 pieces so the line now resembles a very fine pointed tiny SPEAR ! once you manuever the spear point into the tank openings, useing a piece of wire ( I use some aircraft safety wire, about .032 thousandths) but you can use some craft-wire about .020-.024 thousandths (found at Wal-Mart crafts Dept. or other craft stores) going through the tanks fill port I manage the line close enough to the opening so I can get a pair of long POINTED ELECTRONICS needle-nose pliers to grab it with ... you have to feed the line at the entrance point as you pull, OR it will sometimes break off , ( another reason for extra length lines) once you manage to pull enough line out of the fill port past the slit point cut the slit part off ,to make a clean cut, THEN .... EVER so GENTLY pull back on the line, at the entrance hole, to where you have the desired length inside the tank ,if it attaches to a filter assy. attach that BEFORE putting line back into tank (be sure you have enough line in the tank before cutting at the carburetor end ) ALWAYS INSTALL the line FURTHEST AWAY from the gas fill port FIRST ( dont want other line in the way, THINK AHEAD !! )
Sorry to make you read a "book" but I tried to explain it to eliminate questions of procedure I use , ..:thumbsup:
